Display lines on laptop
strangley my laptop displays the edge lines double and in light gray,after latest wip update, on the normal pc it is ok , so where to find the solution for tis as it is a bit ugly only in the ghosted display
nobody suggestions,? ghosted is running slugish with the latest update, it is not my laptop, v5 is running fine in ghosted , v6 was running fine …
so what to do ?
We are still working on display pipeline stuff.
What display adapter are you using?
it is a geforce gt740 , works great with v5 and did with v6 , but after last update not… not the update today
The line display is being worked on right now. You may see improvements in the quality in the next WIP. Performance improvements will not be worked on until we make sure the display is correct.
Thanks a lot
