V6 update: (6.0.17241.13071, 29/08/2017)
So on my ancient laptop the current state of play is as follows: (All view settings are default.)
Ø the picture command simply shows a white rectangle in any display mode ie no picture!
Ø The wireframe, shaded, ghosted, x-ray, technical, artistic, pen & raytraced displays all work as expected.
Ø The artic display shows shaded grey (default) objects on a white background
Ø The render view shows shaded grey (default) objects on a black background
Ø If I select an object that has an environment assigned to it, while in the rendered display, the material panel correctly renders the icon at the top. Since this is the case, and the raytraced display works correctly, I assume this computer is capable of showing both the render and artic views as they should be…?
How can I help this to happen? Does someone (from McNeel !) want to take the computer over and have a look…
cheers
rabbit
Rhino 6 SR0 2017-8-29 (Rhino WIP, 6.0.17241.13071, Git hash:master @ 4ba507bbd3a2d10cc10aa64a48c6283abe2fd544)
Windows 7 SP1 (Physical RAM: 7.9Gb)
ATI Mobility Radeon HD 4650 (OpenGL ver:3.3.11672 Compatibility Profile Context)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: None
Anisotropic Filtering Mode: None
Render version: 3.3
Shading Language: 3.30
Driver Date: 11-16-2012
Driver Version: 8.970.100.7000
Maximum Texture size: 8192 x 8192
Z-Buffer depth: 24 bits
Maximum Viewport size: 8192 x 8192
Total Video Memory: 1 GB
C:\Program Files\Rhino WIP\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino WIP\Plug-ins\RhinoRender.rhp “Rhino Render”
C:\Program Files\Rhino WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino WIP\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino WIP\Plug-ins\CyclesForRhino.rhp “Cycles for Rhino”
C:\Program Files\Rhino WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
C:\Program Files\Rhino WIP\Plug-ins\Displacement.rhp “Displacement”
