The line thickness for the axis X,Y,Z in the display windows are so fine they disapear on the 4K monitor.
How do I make these lines 2 or 3 pixels wide?
Same Exact question for lines I’m drawing. Once the line is drawn I’ve set
view->curves to be 3px wide and that is perfect, but while dragging/drawing the lines are too thin and vanish…
if you mean the World axes in the corner - it looks like you cannot set the width. If you mean the grid axes, you can set these in Options > Advanced > Grid.AxisLineWidth
that has not been made available afaik i remember somebody requesting this either not too long ago. @pascal was there if i recall correct, he might know.
Dragging existing objects seems OK here. But yes, while drawing new curve objects the dynamic display is thinner than the display mode setting (I also have it at 3px on my 4K screens). It doesn’t completely disappear though.
