Display full size in inch on a dimension created on a scale drawing?
V5
I am working over a 1/72 scale drawing and scale photo, but when placing dims I need to see the scale dims and then the full size dim in inches
Currently I am taking a calculator and multiplying the dim in mm by 72 then dividing by 25.4 and typing it in using properties, to the right of the <>.
however if I alter the size of the dimension that inch value is immediately inaccurate.
any other way of doing this ?
(enlarging everything up by 72 is not an option as I do need it at 1/72 whilst working on it.
Steve
Hi Steve,
You can setup the dimension style to add alternative values:
(scroll down in the dimension style settings panel)
Does that work for you?
-Willem
Thanks, I will try that.
Steve
