Is there a way to automatically deduct 1/16” or 1/8” when dimensioning? Currently this is being done manually and overriding the dim. Any help would be greatly appreciated. Thanks.
You can set “display precision” in options to round everything to an 1/8.
Or you can check the “use alternate units” setting in the dimension settings found in properties when you click a dimension.
RM
Ok I see what you want. I don’t have a solution to this outside of doing some of the dimensions manually. For the dimensions that are larger than the linear resolution setting like 22 13/16 this can easily be displayed as 22 3/4 by setting that in linear resolution dim style. See attached image.
But 16 1/8 to 16 1/16 can’t easily be done because your going smaller in linear resolution instead of larger I don’t see a setting for that.
I don’t work with dims that much hopefully someone will have a workaround for you.
RM
