I have my PreviewConduit : public CRhinoDisplayConduit and in ExecConduit I have something like:
case CSupportChannels::SC_DRAWOVERLAY:
CRhinoTextDot* pAn;
dp.DrawObject( pAn );
// also draw a point
vp->DrawInferencePoint(position, RGB(255, 0, 0));
this works ok in the main Rhino viewport, which is fine.
The problem is that I want to ‘capture current view’ and export in PDF. When select File \ Save As… PDF, I don’t see the annotations and points in the rastered output.
How can I overcome this problem? What is the right way to ‘draw’ my objects in the rastered output too?
Just to add that if I use Capture \ Clipboard or Capture \ File it works ok.
Thanks
