Display bug
hello, this problem is a little complicated, I am not sure I will explain well. :slight_smile:
The bug is as the picture shows. I need to show many same size diamonds on the ring, for saving time, I use transforming then use a special component (the third picture shows which I got from shapediver team) to show it. But it seems that it doesn’t work very well. Some diamonds are copied, when I change the size of ring, I dont know where they are from. I don’t think it is from my grasshopper definition.
Thanks
There was indeed an issue with the transformation component. Please replace it with this one.
AttachXForms.ghx (23.4 KB)
