Display background "flickering"
If I have a display mode in which the background is set to Gradient 2 Colors, over here it seems that after each command, the viewport background draws entirely as a solid color which is the Top Color. As soon as the view is updated, the viewport background redraws to the correct two color gradient.
Thanks,
Sam
Thanks Sam; I can repeat this and logged a bug at
http://mcneel.myjetbrains.com/youtrack/issue/RH-30126
I just committed some code that I believe will fix this issue. You should see this in the next WIP release
Just downloaded 6.0.15112.3491, 4/22/2015 and I’m still seeing this. Although it doesn’t happen after each command, now I also often see it when mouse wheel zooming (between each mouse wheel detent if that makes sense, Ctrl + RMB zoom is fine).
Thanks,
Sam
I noticed this is marked as closed, but I’m still seeing vestiges of it in 6.0.15118.10591, 4/28/2015.
Thanks,
Sam
Finally went back to a gradient background, and it is a lot better but still seems to happen a bit after a RhinoScript run (I see it here after something like -_RunScript ( Rhino.ViewCameraUp , Array(0,0,1) ) ). But a whole lot better, thanks!
Sam
–EDIT–
Also seeing it stick after an undo.
