I´ve observed that Analysis component dumps a 69 cm maximum displacement while Shell View indicates up to 47.9 m (see below). This later seems the one shown in Rhino view (the tower is 100 m tall). You can check it here: ShellTower2.gh (60.5 KB)
Is this a bug or am I doing something wrong? Which of them is correct (if any)? Thanks!
Hi @Vigardo, you have an input pluged into R-Factors which is multiplying your outputs in the Legend T. Remove this and then you will see the same maximum value.
Hi Matthew, you’re right, removing R-Factors input solved the issue. I thought it worked different, sorry for the stupid question and thanks for the quick response!
