Displacement Analysis
I want to calculate the displacement of a fully parametric structure under equivalent earthquake loads. The Karamba 3D component only provides the maximum displacement; however, I need to determine the exact location of this displacement within the structure (whether in a column or beam) to verify the accuracy of my analysis. Additionally, I want to obtain the displacement values separately for each floor. Can you help me with this?
Hi, you can use the nodal displacement component to find the displacement of each node in your model: 3.7.1.5 Nodal Displacements | Karamba3D v3
