if by ‘lowest’ you mean ‘position’ (below the others) then place a point on such curves, grab the Z coordinates and plug into sort list along with your curves - once ordered based on Z your ‘lowest’ curve will be the first item resulting from sort list
I managed to find an end point but for some reason the script doesn’t work, there is sth wrong when I deconstruct the point. It probably is sth very easy I just don’t know Lower curves 2.3dm (15.5 MB) Lower curves_2.gh (28.0 KB)
But it doesn’t seem to create a sphere?
I need to pick the lowest curve which sphere will not intersect with any other breps.
Like in this image from one of the first scripts.
