Hello dears. Is there a disassembler script or command to fully display the internal parts of a model. For example, like this:
Hello- ScalePositions
can help- it may not always do exactly what is needed but it can get you started. See also NamedPositions
, which will be needed to restore the objects.
Thank you so much dear @pascal .
Due to the fact that the number of parts is large and each one must be moved in a deferent direction, so a sense of intelligence is needed here, which, as you mentioned, is not the case with this command. Of course, it helps to some extent
-Pouria
