In WIP 5.3, any tool palette I open disappears after selecting a tool and using it once. For example: I select a palette from Active Tool Palette’s Menu and it shows up on the screen. Once I select a tool, the tool palette disappears from view even though there is still a check next to it in the Active Tool Palette’s menu.
I first noticed this when trying to add notes in layout mode. If I select the drafting palette, then a tool, click, then no more palette. I have to open the palette again. Is this behavior to be expected or should the tool palette persist on the screen?
Thanks for any Help,
Stephen James
