Disactivating of slabs when using BESO for beams
Hi!
I have met an problem I cant find solution for. I am trying to use the BESO for beams to find optimized amount of wind bracing. The problem occurs after the BESO- optimalization, it seems that some of my slabs are being disactivated during the optimalization. I cant quiet understand why my slabs are being disactivated under the optimization. Have somebody else had the similar problem?
Hi, can you please share your script here.
PartOfTheCodeWithBESO.txt (11.9 KB)
KarambaOptimization_V2.txt (70.6 KB)
KarambaOpti2.gh (56.0 KB)
I am sending you the whole component (Karambaoptimization_V2), but since it is quiet long and chaotic code I am also sending you the code snippet (PartOfTheCodeWithBESO) where I use the BESO-Opti. I am also sending you GH-file with internalized Karamba-model.
I tried to use BESO for beams both with coding and inside of the Grasshopper, but I get the same same problem with my slabs.
hi, we cant open the script because you use a unique plugin, are you able to remove this from the script?
