Is there a way to disable auto-scroll/pan during a box selection ?
Regards.
Regards.
Hello - so far, I do not see any way to disable this.
Technically in Rhino 7 you can “lock” the view from the viewport menu, so the viewport can’t be changed.
The funny part is that the box selection in that case keeps moving as if the view was being scrolled, but the view stays put. @Pascal- this may be considered a bug in box selection with the new ‘locking view’ behavior introduced. If not for this, the above problem could be solved by locking the view.
–jarek
Hm - I see that, thanks. That is a little odd. But even when fixed, I am not sure this is really other than a makeshift solution for this request - I guess if users really need to turns this off there ought probably to be an ‘advanced’ setting for it.
RH-62206 Selection: Panning locked views
RH-62213 Selection: Disable auto pan
My wish for Rhino 6 and later :
In my point of view, using locks is a relevant tool but has nothing to do with selection.
Regards
Hi Lahos,
To be clear, I was not referring to locking objects.
In Rhino 7 there is a new viewport feature where user can lock the view so it can’t be manipulated, or auto-scrolled for that matter. It might have been a good workaround if it did not act funny as described above. Maybe it gets fixed, otherwise an option to enable auto-pan is a good suggestion.
You could have a key shortcut to lock/unlock the view using the new _-LockViewport
command.
It is also on the View menu here:
Still sad to manage every views one by one to disable scrolling during selection.
Regards.
