Disabling Cull
Hi, Is there a way to disable cull without disrupting the flow of the script? At the current moment, when I disconnect the zero from the function, the rest of the functions cannot continue. I would like to be able to set a boolean of sorts, such that I can choose whether or not I want to enable or disable the cull index without disrupting the rest.
Thank you
Something like this?
That’s Set->Tree->Stream Filter
Thank you so much! It worked
