Hi All,
Is there a way to disable the tooltip while getting a point constrained to geometry with RhinoCommon?
Rhino Options > Cursor Tooltips is not enabled.
Thanks, Jess
Hi All,
Thanks, Jess
Hi Jess,
No, this is not possible from RhinoCommon. Why do you want disable cursor tooltips? Is there a problem it is causing?
– Dale
Hi Dale,
Well a user of the tool I’m developing is running it on German Rhino and the tooltip is something like “aufPolygonnetz” or so. This is covering lot of the textured mesh the user has to trace. Since the information of the tooltip is redundant in this case it would be nice to disable it. Take it as a wish
Thanks,
Jess
Hi Dale I am working on a script to dynamically display the slope direction of a terrain mesh, and the tooltip is too large so it covers up (part of) the result, making it difficult to see. Are there anything that can be done to turn the tool tip off?
@Holo, no there isn’t anything you can do at the time. But the item below will help.
https://mcneel.myjetbrains.com/youtrack/issue/RH-37464
– Dale
