Disable Gumball Cut Handle
I don’t find it useful in my workflow and it interferes when I accidentally click the vertical bar.
If I could scale the handle size to zero that would give me what I need but I could not find a setting.
Is there anything that can be done about it?
Are you referring to a gumball setting? Push pull is an icon or command…
a screenshot showing your problem would help-
You are right, I was referring to Gumball’s functionality.
Apparently, I mixed the two features.
Hi, in the GumballSettings command click the Handles option
Then set the CutHandle option to Off
Then it will no longer appear for you even if the selection is able to be used for cutting
Can we rename the topic if this is about the Gumball CutHandle?
Done
Thank you very much @Joshua_Kennedy !
