I know this is actually presented as a feature, but is there a way to disable the automatic preview of Grasshopper Geometry in V-Ray?
I would like much more if it was off by default, but could be enabled with a simple component, a bit like custom preview.
I have a file where I need to see the Grasshopper geometry in the viewport, but not in the render and always switching back and forth is a bit tedious.
Hi seltzdesign
I didn’t get that
Pure grasshopper geometry won’t appear in the renderer unless plugged in to a VGeo component
Even if plugged, you can set it as invisible, and it will not be rendered.
And which renderer you’re talking about ? V-Ray in Rhino (populated with GH geometry by the RenderInProject component), or V-Ray in Grasshopper ?
