Hi
Im new to grasshopper and trying to make a contour with a direction that is -x ?
But every time i try the direction moves in +x
Can anyone help?
/Astrid
Hi
Can anyone help?
/Astrid
Hey, u can share screenchot and we will see…
Contours are always made across the entire object. The start point doesn’t really specify the first slicing plane, it specifies a slicing plane, and more planes will be created on either side of the start point until the entire shape has been contoured.
So a contouring direction of -\hat{x} or +\hat{x} amounts to the same thing. They are indistinguishable.
If you want to contour only a portion of a shape, you’ll have to use the Contour Ex component, which allows you full control over the amount and offset of each slice.
Thanks I’ll try that funktion instead
