Direct3D rendered viewport is creating some squares. (8x8 pixels)
Those are Rhino glitches , not video compression artifacts. When I change the object color to green, the top/above glitches are still red.
Once a geometry pass through the square, the square then behave differently, remembering the color of the geometry…
This is not a new bug here, I’ve seen this since the first time I tried Direct3D on Rhino WIP… I hoped this was going to disappear on more mature releases.
Oh, during a command prompt, or if there is something selected (even a curve/point) those glitches disappear.
More specifically, even with gumball off, if I can see the selection (yellow highlighted) on the rendered viewport the glitches disappear, as soon as the selected object is fully outside the viewport, the glitches appears again.
Edit: this seems related to Antialiasing. If set to “None” the problem disappears.
Summary
Rhino 9 SR0 2026-6-30 (Rhino 9 BETA, 9.0.26181.12303, Git hash:master @ 63db21acdecff631b4b3c30057580aaff9bf8c35)
License type: Commercial, build 2026-06-30
License details: Cloud Zoo
Expires on: 2026-08-14
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 10.0.2
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: AMD Radeon RX 6700 XT (AMD) Memory: 12GB, Driver date: 6-19-2026 (M-D-Y). DirectX(11)
> Accelerated graphics device with 7 adapter port(s)
- Windows Main Display attached to adapter port 0
- Secondary monitor attached to adapter port 1
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Zen MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26181.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26181.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26181.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26181.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26181.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26181.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
