I have a feature request for dimensions’ visibility. That would be fine if dims would be linked to selected Clipping plane in terms of sections. When I have several section and I place dims on the plane It could be overlapped on the plane behind the active CPlane. So the series of dimension would be visible on the current Clipping plane (Cplane) only and other dimensions on different plane would be hidden.
Not sure if you understand that CPlane is not ClippingPlane - it is short for “Construction Plane”. Clipping planes clip views. Construction planes are reference frames for creating geometry.
To address your dimension visibility problems, maybe you can put sets of dimensions on layers you can turn on and off for the moment.
