2DCube
1
This is probably me but I have checked a couple of times.
Where is the match option in the dims properties panel, please?
Also, I don’t seem to be able to scroll through the properties listings if I expand too many options they fall off the screen.
Cheers
Andy
pascal
(Pascal Golay)
2
Hi Andy - checkin it, thanks.
You’re right, there is no Match yet - https://mcneel.myjetbrains.com/youtrack/issue/RH-37948
I’m not sure about the scrolling - do you mean you do not get a vertical scroll bar if the dimension Properties page is too short?
2DCube
3
Hey Pascal,
Yeah, if I open two or three sub menus if falls off the bottom of the screen and I can’t see what’s at the bottom of the list?
I have to close a couple in order to keep them on the screen to see. I’m guessing it’s work in progress or my system but thought I’d flag it.
Cheers
Andy
pascal
(Pascal Golay)
4
You should get a scroll bar on the side - do you not get this? It does not exactly jump out at you, it’s somewhat low key as controls go :
2DCube
5
Hi Pascal,
No joy over here: http://screencast-o-matic.com/watch/cbnoXv66Mu
I’ve noticed that if I make the window smaller the bar appears but it still doesn’t scroll through the listings: http://screencast-o-matic.com/watch/cbnoX466My
I’ll update my drivers and have another look
Andy
pascal
(Pascal Golay)
6
Hi Andy - thanks - I was testing with the control cut off by another docked thing below it, I’ll try with it at full height.
Alain
(Alain Cormier)
7
Hi Andy,
The scroll bar that Pascal is showing is not in the last WIP but will be in the next one.
Alain
