Dims and objects visible in Top front and perspective not vis in left
V5
What can I do to find out why dims I have rotated downward and objects such as sphere, dont appear in left view when are visible in the three other views. ?
Hi moved an aboject and it started to appear,
Clipping Plane !
how do I turn its effect off ?
select layer select objects properties and tick box for left was ghosted.
why is that ?
Steve
To turn its effect off:
  1. Select the clipping plane object itself — it’s a flat rectangle in the model, easiest to grab in Perspective or Top.
  2. Open Properties and click the Clipping Plane page.
  3. Under views clipped, uncheck Left — or just delete the plane if you don’t need it at all.
On the ghosted checkbox — those view checkboxes only exist on the clipping plane’s own properties. If you had the sphere/dims selected (or a mixed
selection), the options grey out. Select just the plane and they’ll be live. Also worth checking the plane isn’t on a locked or hidden layer, which would
stop you selecting it in the first place.
