If I am using alternate text for dimensions, and that alternate text is set to use Feet & inches, the precision pull down still gives precision as decimal units instead of fractional units as it does for the primary units.
Thanks,
Sam
Thanks,
Sam
Good eye… I’ll file it for a tune up. Thanks.
Hi Brian,
Im working in a MM file and went to use the Alt Text to dimension an object with Imperial dimensions as well. Both Fractional and Feet and Inches are set to decimal precision. Could this get updated?
Thanks!
Andrew
