Radial Dim.3dm (36.6 KB)
maybe something wrong with the geometry, can you post it?
Hi @Asterisk,
That’s a repeatable bug. As a workaround, if you Explode the blue line the dim will place wherever you want it.
Regards
Jeremy
I see this - my first thought was that it was due to the curve’s self intersections but that seems not to be it… still poking at it…
SimplifyCrv
seems to help.
https://mcneel.myjetbrains.com/youtrack/issue/RH-53386
I did post the file.
sorry missed it
@pascal I made another, see attached. It appears to be drifting away once your cursor is closer to the straight line than the arc
thisonetoo.3dm (20.1 KB)
Hi Gijs - that one seems to behave as expected here so far… weird. If I Explode/Join then it does the bad thing.
