DimLinear wrong preview
Why doesn’t the DimLinear component display the correct preview?
Black dim: Rhino :white_check_mark:
Green dim: Elefront :white_check_mark:
Red dim: GH DimLinear :cross_mark:
When I bake it, it comes out just as it should.
You’re not referencing the annotation style correctly.
What you’re doing is basically creating a new annotation style.
Use the Query Annotation style component instead to reference
thanks @martinsiegrist
So, when it was baked, it must have been created at the correct scale due to a name conflict.
Possible.
Are you aware this is not the preferred way to bake an annotation?
Yes, I have been using elefront for annotations, attributes and baking. I am trying to integrate the new components introduced in R8 into our scripts.
On a related note, I’m trying to use the text overwrite parameter, and this as well, only take effect when baked. Say a string for T: Length <> mm, only the number (red) is being preview, but when baked (yellow), it displays correctly.
Much appreciated!
Hi Yunbo -
This issue is on the list as RH-95142 Grasshopper: Dim Text Override is Not Displayed
I’ve added your post.
RH-95142 is fixed in Rhino 8 Service Release 34
