I just noticed that when I made an “assembly” from Blocks (solids) and then tried to apply dimension on the solids, the dimension commands didn’t seem to recognize the blocks as regular solids.
Is there a work around for this?
// Rolf
// Rolf
I’m not able to reproduce that here.
Hi Rolf - is this also true in the simplest case - make two boxes, Block, and dimension the boxes in the block…?
I didn’t try all basic solids, but I made a box, Block, and tried Linear Dim (OK, worx), then I made a cylinder, and nope - Diameter Dimension won’t detect the circular edge.
// Rolf
Hi Rolf - I see that - thanks. It appears to be fixed in V6…
