OK, I just ripped apart my drawing to try and get rif of an extra 1/4" I just couldn’t seem to find. And, well, here it is… (image and file attached)!
ALSO: Why is this file 9MB???
ALAN FARKAS - RHINO BUG MAYBE.3dm (9.0 MB)
Hi Alan - you’ll find it if you set the dimension precision to 1/64 (say).
k will check thx
also - do you know this is 9mb? I deleted everything in the file
Yep - there are layouts and off layers that have stuff on them including block instances , in addition there are bitmaps in the file bitmap table (Use Audit3dmFile
to see the bitmap table contents listed) . If you turn on layers and delete stuff, plus the layouts, then Purge
and then for the bitmaps, testPurgeBitmapTable
, things get more reasonable.
