I’m fighting with a bug? Every time I manually change the “Linear resolution” in the properties of the dimensions from 0.1 to 1, saving and closing the document, when reopened the dimensions are reset to the 0.1 value. Seems that they can’t save the state of manually changed resolution to 1.
I’m not seeing that here - but I might be doing something else than what you are doing…
Are you overriding the properties of a specific dimension or the style?
Can you post a simple model?
In this picture, the dimension under the cursor has linear resolution set to 1 and it remains like that after closing and opening the file.
Can be because I am saving always as Rhino5 files for compatibility?
Well… YES.
Dimensions are not backover compatible…
