Probably doable.
this looks really useful, and so needed inside Rhino, is this script available, or still a wip ?
Works well as is, but it is still a work in progress.
Do you have a link to try it out bud ?
Just in case you want to share and want to make sure people stay on the latest version of your script, you could share it on PackageManager. Let me know if you need more info about the process.
Not yet.
That is the plan. Thanks.
Quickly place multiple dimensions from a common point;
this looks awesome!
you meen two points between dimensioning points + one through point to define plane where to place dim?
Something like that.
just thinking. it could be that when you only click two points then orientation reacts to cplane and you can flip orientation with tab (or some other key), when you click third point then there is tentative new cplane and tab flips orientation in reference to that.
