Dimensions Floating Above Ticks
Hi all,
I’m trying to dimension an elevation view using Inch-Foot Architectural Style, but the problem is that the actual dimension value is floating way above the tick marks. I took pictures to show my current settings and the problem.
Dimension Floating:
Current settings for this annotation style:
Thanks in advance for any help!
Hello - Does DimRecenterText sort it out?
Can you post an exmaple?
Please also copy/paste the results from the Rhino command SystemInfo
did you try to save the document, restart your computer and rhino ?
:roll_eyes:
Turns out it was user error, of sorts. Apparently I can just click on it and use the red gumball square to drag it in/resize it that way… Thanks to both of you guys, sorry since it was an easy fix😅
