Hi all - I’m having an issue in Rhino reading dimensions from a DWG export in Revit. The dimensions are always out of scale, and radial dimensions aren’t visible in Rhino. Does anyone have a tip for this? Manually changing the dimension scale directly in Rhino is a bit tedious.
