would be possible returned properties “status bar” with dimension value, when is dimension selected - like in V5?
Is very helpful when i have large drawing with small dimensions - is not necessary constantly roll to zoom…
V5:
V6:
V5:
V6:
Hello - so you’d like the white field for the dimension value moved back to the top, correct? (Also, it seems to me that field takes much more vertical space than it needs to.)
OK, I see now what you’re asking- I’ll get that on the bug pile.
no no, i would like get back the grey field with real value of dimension. In V5 direct under white field…on image with value “14.00”…
Hello - yep, I got that now - thanks.
https://mcneel.myjetbrains.com/youtrack/issue/RH-46670
Also
https://mcneel.myjetbrains.com/youtrack/issue/RH-46671
yop. thank you!
RH-46670 is fixed in the latest Service Release Candidate.
