Dimension Tuneup
@lowell
Here is a dimension that is not handled very well.
Dimension Tuneup.3dm (56.7 KB)
HTH,
Don
Right. The work-around is to change the text location for that dimension to outside of the dimension line, or turn on it’s control points and manually drag the text to a location that fits your model better.
@donl517 - Thanks for the persistence. You’re right. It should be drawn better.
zero suppression (it’s in the dimension style units flyout, I think - in Options) will get rid of all those 0s, too.
Bug report here:
https://mcneel.myjetbrains.com/youtrack/issue/RH-47716
link doesn’t work.
The link should be good now
