Dimension tool - font size
Hopefully the dimension-tool standard settings are still part of the development process. Usually I’m using one of the mm templates. The standard font size of the dimension-tool is always far too small. And it doesn’t matter if using the large object template or small object template. At the end the user needs to change the dimension settings in the settings menu. It also doesn’t save or keep new created dimension styles. As soon as I start with a new file all the previous created dimensions are gone.
I literally came here just now to ask about the same thing. I thought I was misunderstanding something but maybe it’s a bug.
cheers,
Michael
Dimension styles are part of document’s settings. Create a template with all the styles you need.
