Hm, okay, its weird. it works sometimes. From what I can work out:
Enable OneView. Move to say a view where it says “front” in the top right. Then click on linear dimension. Nothing happens and its not letting you create a linear dimension in Z. But, if you then right-click it will repeat the dimension command and now the cplane will automatically switch to a front view one and you can draw a dimension in Z.
But why only when I right-click and not when I just click on the button for linear dimension?
I recorded a small video to show what I mean. It should work in theory, but I don’t know why it is not switching the CPlane when I hit the button, but it does if I use right-click to repeat the command!?
@wim I just noticed that using OneView was your suggestion all along and I didn’t really see that back then. Can you confirm that OneView is working as intended in the video? It seems like a bug to me that the CPlane doesn’t change as soon as I launch any command, but only when I right-click and repeat the previous command?
Also it doesn’t set the CPlane back to top once I finished the command, even though ReturnCPlaneToTop is set to Yes !?
you may need to roll your view just a bit farther to get the cplane to change 1st, then run the dim command- it does work as expected here.
I’m guessing you are using a space mouse by the way your screen moves? Not sure if that has any effect on your results. I’m using a standard mouse here.
We have RH-66326New DIM Align Options logged as a feature request for a Rhino.
This may eventually influence how other dimension like Leader, Radius, Diameter, Angular behave. Once we have DIM working, we will consider the other as well.
Oneview seems to be a nice work around. Thanks, @theoutside.
When there is something in the WIP ready to test, this thread will be notified.
@theoutside That is correct. Did a little test and it appears that OneView only automatically updates the Cplane when holding the right mouse button to pan. If you use a SpaceMouse OneView does not update the CPlane. I think OneView should either get an option to only work on right mouse button or rather it should not be set to only respond on right mouse down, as using a 3D mouse is at least one way of navigating without a mouse button being pressed. But I dont understand why it would need to be tied to a mouse button being pressed anyways. The point of OneView is that it updates on the fly, so surely it should not matter what I use to navigate the viewport.
@mary could you maybe add this as a ticket as well? Otherwise OneView is useless to us, even though it totally makes sense.
Just came across the system requirements for Rhino and noticed that the SpaceNavigator and SpaceMouse specifically get mentioned as “optional” in the requirements (which kind of doesn’t make sense, but okay).
spit out my coffee. lol. It’s astonishing that 3D mice are still such a secret though. They should be mainstream by now, plug n’ play drivers by default, many different brands/designs etc. – but no, there’s maybe 3 brands to choose from, and the drivers are so bad.
I agree. But unfortunately most ppl get dizzy or something and their brains can’t adapt to the 6 degrees of liberation.
it’s been a bit more than a year and I’m curious if this is being worked on? I am on the latest WIP and it’s still not working correctly. The label in the top right updates correctly, but it doesn’t set the actual C-Plane until you move the mouse. It kind of defeats the whole purpose of OneView and using a SpaceMouse as recommended by McNeel.
Is Giulio Piacentino no longer at McNeel? From the Youtrack item it seems like he had a solution (ie. do the same as in Rhino for Mac) and was waiting for some okay by @stevebaer. Nothing happened after that and in Rhino 8.9 it is still not fixed.
Are we ever going to see this simple fix?
You officially support the SpaceMouse, yet a very handy tool that should work with it does not. I don’t know why things like that never get prioritised over a million new things?
Regular check-in to see what the status is of the Youtrack. @stevebaer Could you take a look at the changes suggested by Giulio Piacentino? Any chance we can get OneView support for SpaceMouse in Rhino 9?
