I think this question has been asked before but is there any option/function to modify a dimension, like we can find in other CAD software, by clinking on the dimension arrows?
Or if there is any sort of function like that, how can I modify a dimension?
Hello - what do you want to modify? The locations of the dimensioned points? You can turn on control points (F10) and move them, or modify/append to the text in the dimension’s Properties.
hi, yes sure it is possible if you just follow a different chronology. you can add dimension which are auto updated. then just activate the point and use scale 1d then enter the new length done. the dimension will update along.
