In the attached file the dimension leaders are really long, even though I have every setting set short.Mount Print.3dm (624.6 KB)
Also, the scale on any layout is not carried over to V6, when I open a file in V6, that was made in V5 1/2 scale, the dimensions are all half.
pascal
(Pascal Golay)
February 9, 2018, 12:57am
2
Hi Don - thanks, I’ll check this.
@Don , I see this in your file but I can’t make it happen so far - if I make new dims I get something like this
Was this made in V5 and then opened in 6 or?
Pascal,
Yes, it was.
I just ran a test, this only seems to effect ordinate dimensions. The attached file was made in V5, when opened in V6 the ordinate dimensions values are scaled by 1/4. Test Dimensions.3dm (43.2 KB)
File created in V5, then opened in V6. The ordinate dimensions are wrong. If I create new ordinate dimensions in V6 they are correct.
HTH,
Don
pascal
(Pascal Golay)
February 9, 2018, 4:45pm
5
