When you are making a simple surface in 3D there’s a good option called Plane 3Point, which lets you pick a direction in 3D space and extrude from that.
But why isn’t there the same for dimensions?
I hope I missed something, because trying to do 3D dimensions in a 3D view is currently absolutely a horrible experience to me (so I always switch to a 2D view but that often involves isolating objects and other extra clicks).
+1 to this. Basically a tool that works like Distance but with the added dimension annotation. Regarding Rhino I find the whole exercise of first picking a dimension style (vertical, aligned, diameter etc.) cumbersome compared to most other CAD packages that automatically detect the type of dimension you’re trying to create.
Ahh, ok… CPlane also has a 3Point option, so I guess I could do that first instead of switching to a 3D view (although, again, initial testing reveals that the order in which you have to click the three points is reversed compared to Plane if you want to a horizontal/vertical dimension so again, that famous Rhino UI consistency!
I don’t understand what you are comparing it with…
Plane (the surface command) with the 3Point option asks you for the first corner (that is the origin) the length (that is the X axis) and the width (that is the Y axis). Where is the inconsistency?
