It appears that my dimensions are displaying the generic “Length Resolution” when I change the dim style from decimals/mm to feet and inches/feet.
Here’s the WIP v I’m using
Work In Progress
(6.0.17136.10381, 05/16/2017)
WIP
And here’s a view of the issue, you’ll see that the correct dimension is showing in the dim object property’s bar on the lower right:
I thought it might have been the dimension scaling, but that doesn’t add up.
Thanks
devin
Alain
(Alain Cormier)
2
Hi Devin,
Do you mind attaching the file so we can look at it?
Thanks
pascal
(Pascal Golay)
3
Hi Devin - do you still see this in the latest WIPS?
pascal
(Pascal Golay)
5
Hi Devin - can you post an example file - just a simple rectangle or two is fine - something that shows the problem.
thanks
Hi pascal, sorry for the delayed response. I believe this was due to the dimensions properties, as I’m still getting used to all of the new settings.
Thanks
