Dimension edition no more saved
I create a dimension
then edit it, the new text is well displayed
click on OK, the dimension edition is not saved.
I have to purge the history of the dimension first, then it works. But it is a bit confusing. Should I be able to edit the dimension without purging its history ?
Version 6 SR8
@Alan - I haven’t been able to duplicate that here.
Are there any more details you think may be involved?
I tested in Version 6 SR8
(6.8.18240.20051, 8/28/2018)
Just tried with a new file, still same problem.
2018-09-28 AB - Rhino6 dim edition not saved.3dm (27.9 KB)
Hi
I’m not able to repeat this either.
Any chance you recently installed some Windows updates are are in limbo waiting for a reboot?
See if restarting Windows makes this problem go away.
Any luck?
Windows 7 64 bit restarted.
I am still able to reproduce it, even with a new file
