Hi.
video attached, link later on…
V4
I use this method to create all my known dimension lines, and I create thousands.
Simple situation. horizontal line starting from somewhere on a vertical line.
to create a dimension of a known length along the horiz line from line’s end. (jnctn with vert line)
- click start of dimension at end of line (Int Osnap)
- enter length e.g. 100 and click on the line (Near OSnap) along which you want the dimension, end of dimension appears as a square 100mm along from the first click in 1.
- click anywhere on the line (NearOsnap) and a moveable dimension arrow at each end with 100 in middle appears, moveable up and down
- click on line (NearOsnap) to set its position on the line, (or click somewhere else to get extension lines to the line.)
result a dimension arrow at each end for 100 sitting along the line starting at line end.
V5
- enter length e.g. 100 and click on the line along which you want the dimension, end of dimension appears as a square
- click anywhere on the line (Near Osnap) and the end of the dimension changes to where you clicked, we now have 61.34 instead of 100…oh dear
the rest of the process is lost as we now dont have 100
More often than not I dont even get that but I get 0.00 as a vertical dimension at a position on the line where I clicked in stage 2.
Something drastic has changed and I cant place dimensions anymore.
I have to place loads of dims from datums and its taken me an half an hour and I managed 100mm but once !
Whats going on in V5 ?
see video http://www.screencast.com/t/YeKO2evOBB where I type in 100 each time and hit enter. Only in V4 does it work correctly.
starts with V4. Oddly enough in this test vid I didnt get the vertical 0,0 to occur.
Steve
