Dimension Baking Problems
I am learning/experimenting with Grasshopper Dimensioning. The aligned dimensions perform fine in GH, but when I bake the model and cut/paste it into another drawing, the dimensions do not come over.
Can anyone suggest something to try to make the dims bake?
(or other reason about what’s going on here?)
Best regards,
B
Hi blcavender,
Not seeing this in a quick test.
Please run SystemInfo in the Rhino command line and post the results.
A small example file would be helpful as well. Thanks.
Here is the sysinfo:
Rhino 7 SR37 2024-4-16 (Rhino 7, 7.37.24107.15001, Git hash:master @ d2e42f70b9d3aa58f6053e2998a0db2abcd7555b)
License type: Commercial, build 2024-04-16
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 14Gb)
Computer platform: DESKTOP
Primary display and OpenGL: AMD Radeon™ RX Vega 11 Graphics (AMD) Memory: 2GB, Driver date: 2-20-2024 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 24.3.1.240216
> Accelerated graphics device with 5 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 2-20-2024
Driver Version: 31.0.21912.14
Z-Buffer depth: 24 bits
Total Video Memory: 8924 MB
C:\Users\Bruce Cavender\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ProRender\1.0.1.5\ProRender.Windows.rhp “ProRender” 1.0.1.5
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.37.24107.15001
I found a work around in that I can bake each Dimension plus the final geometry separately … which creates the end product of a dimensioned geometry.
Each AlignedDim object must be baked individually. Just baking the SolidDifference alone doesn’t trigger the baking of everything.
I’m wondering if there is a way to link all the objects somehow to “BakeAll”?
Tnx!
B
