DimArea Text Alignment Unexpected Behavior
Hi all,
I found some unexpected behavior when trying to center justify text with the DimArea command.
When I change the text justification, I can see that the control points move, but the text remains unchanged.
Here are three screenshots that capture the issue, and an example file below.
See the example File210916_MullionExtrusionAreas_v0.0.3dm (3.2 MB)
And system info:
Rhino 7 SR8 2021-7-15 (Rhino 7, 7.8.21196.05001, Git hash:master @ 45c1fd6dc85c7c1cce8c0bbe6f3e16481ae9abfa)
License type: Commercial, build 2021-07-15
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 64Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 9-5-2020 (M-D-Y).
Primary OpenGL: NVIDIA Quadro RTX 4000 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 7-7-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.98
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-7-2021
Driver Version: 27.21.14.6298
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\Alexanderj\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
Hei Alexander -
Yea, I see the points getting repositioned but when you deselect and reselect, they are back where they ought to be.
Apart from that, it doesn’t make much sense to align/justify anything to just itself. If you add another line to the text, the alignment is as expected.
Hi Wim!
(Always good to hear from you)
I was expecting the center align to change the text so that it aligns onto the leader line… but I can see now that the leaders are really intended to be used for horizontal alignment only.
This little tick box for a Landing was a nice solution for me:
Hei Alexander -
That does make those leaders clearer, yes.
I’m not sure if you’d want the text to be vertical, but that’s also possible:
