I am hoping to get some guidance for developing this script. The goal is to create a surface attached with a DimArea text. I am not sure what I’m missing but there are two issues so far:
Selprev doesn’t select the newly created surface (it selects the surface if I run the macro directly from the macro editor)
Once it selects the surface it then asks for Text Position. I would like the text to be centered on the surface so I thought moving the “dimArea” would be the way forward. Is there a better way to do this?
srf = rs.AddPlaneSurface(rs.WorldXYPlane(), 5, 5)
area = rs.SurfaceArea(srf)
if area:
cen = rs.SurfaceAreaCentroid(srf)
if cen:
text = round(area[0],2)
text = str(text)
rs.AddTextDot("Surface Area: " + text, cen[0])
print "The surface area is: " + text
srf = rs.AddPlaneSurface(rs.WorldXYPlane(), 50, 50)
rc = rs.Command("_DimArea _Type=_Text SelId " + str(srf) + ' 0,0,0 ' )
if rc:
dimArea = rs.LastCreatedObjects()[0]
pt = rs.BoundingBox(dimArea)[0]#<<< the lower left pt in the bounding box
rs.MoveObject(dimArea, rs.SurfaceAreaCentroid(srf)[0]-pt)
i.e. use the id of the created surface to select it in the DimArea command. Note when you go out to a Rhino command the result is not an object id or ids as when you create the object from a script function - you need to get ‘LastCreatedObjects()’ , always a list, and in this case the first and only object in the list, hence the [0].
Thank you @DanBayn, this definitely works in terms of displaying the surface area but it doesn’t update the value like Dimarea does when scaling the surface.
