Is there a way to always display the distances between two points (A–B and C–D) when there are multiple points?
The easiest way to always have dimension displayed is to launch grasshopper, reference these two points, and attach them to “Linear dimension” node. (and make sure to have “Draw shaded geometry” turn on)
Even if you move points in rhino, the dimension will follow a change.
You just can’t close grasshopper.
If you are new in grasshhopper:
- type in Rhino: Grasshopper
- in window that appeared double click left mouse
- type “Point”; left-click on the black one with X, and then left-click on canvas
- right-click on what apperaed(“Point” node), left-click “Select one point” and then select the first point in Rhino
- repeat 3-4 with secound point, and add “Linear dimension” node simmilary how you added “Point” node, and conect them like in screenshot
If it was obvious for you, then I’m sorry ![]()
I hope that’s the result that you wanted to get.
