Look at the image, and check Number of Panel B, and Result panel C
When i write 110000 in Panel B, it makes error,
It’s a kind of “Target Invocation Exception”
i can’t understand. anybody know?
Is there digit limit in Grasshopper?
Yes, there is an integer limit in each an every computer program. Now, the limit usually depends on the type (int
, uint
, long
, etc.) and language the program (C#, C++, Python, etc.) was written in.
Since, Grasshopper was allegedly written in C#, it’s limit for integers of type int
is 2147483647 (cf. reference), which would be smaller than the result of your last multiplication; 16500000000. That’s not to say that Grasshopper doesn’t use another type that allows even bigger numbers, but I’m pretty sure that you are overflowing the limits here.
Thanks for your kind reply.
Now i know that it’s very basic issue on computer program…
