Diform cabels with unary force
I am new on this Forum and also new in using Kangaroo.
I am trying to built a facade which is built with cabels which are acting a little bit like a curtain.
The princip is the following: I have cabels which are streched from the top all the way to the bottom of the building. The cables should move aside where there is a window (see JPEG concept).
I try to do this with Kangaroo, I use unaryForce which are placed on the top and on the bottom of the windows (see Jpeg Unaryforce)
and the springsfromline component for the cabel. Unfortunatly it didn’t work as I expected. It’s seem that the resulting curves are going through all the anchor points and dont react to the forces.
Do you think is possible to do what I want with Kangaroo? Is it possible to keep the data tree apart (separated) with kangaroo, is maybe that the reason why it didn’t work?
I also have a global question about Kangaroo: should the Object on which the forces are working and the force itself be pluged into the Input Force objects ?
How does Kangaroo recognise which is which?
Kangaroo facade.gh (14.1 KB)
facade cable.3dm (51.0 KB)
