Difficulty extracting Make2D of complex voronoi structures
I’ve created these beautifully intricate Voronoi structures that I would like to Make2D taking plan and section cuts. Unfortunately, I get really simple outputs that don’t show the complexity of my geometry, not showing the details inside. I’ve tried using different views and isocurves (my object is made of many surfaces so doesn’t apply) and I am still getting a very botchy output. Any ideas on how I can do this quickly and effectively, likely with tools in rhino as I am very new to using these software and will need to generate many section and plan drawings.See attached. Any help is greatly appreciated!!
Geometry20250316_175522.3dm (14.4 MB)
Don’t know if this can be a little better…
I would try to obtain the silhouette with the MeshOutline command (it seems to work better than the silhouette command) and mix it with the Make2D command.
You can apply different thickness and color to identify better the object’s regions.
Some curves have to be deleted or trimmed because the make2D output isn’t perfect (some problems are also where the object self intersect itself so the command cannot understand where to cut curves).
